01 blazer 4wd not releasing
3 or 4 button switch on the dash?
Is it equipped with a 3 port vacuum switch on the transfer case, driver side, inboard and above the encoder motor?
![Name: NV233selectable.jpg
Size: 40.6 KB](https://blazerforum.com/forum/attachments/2nd-generation-s-series-1995-2005-tech-41/31910d1501273162-01-blazer-4wd-not-releasing-nv233selectable.jpg)
Unplug the 2 vacuum lines from the vacuum switch, engine at idle, select 2WD: One port on the switch should hold vacuum when you suck on it
The other port should be vented to atmosphere.
The port that holds vacuum must have the engine vacuum line connected to it. The line that goes to the other port goes to the actuator under the battery tray.
This will tell if the lines got transposed, (switched around).
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
justblazin1
10-19-2014 11:12 AM
cory30189
01-31-2013 07:04 AM
ensembledwar
03-07-2010 12:13 PM
LYK2ROC
12-05-2008 07:08 PM
Mikes1Addiction
01-12-2007 02:08 PM
