01 Blazer engine light problem asap
Old Jun 12, 2010 | 01:10 AM
filoblazer's Avatar
filoblazer is on a distinguished road
Default 01 Blazer engine light problem asap
Hi went out today and realised that the engine light is on. I pulled over and checked d oil, still in full reading. So I checked the break fluid, fuel cap and found the power steering needed to be top up. I did that, still engine light on. Any idea what's wrong? is it safe to drive with the light on??
Old Jun 12, 2010 | 01:38 AM
kiwiblazer's Avatar
Should be. You'll need to get codes read to check what's wrong. Do it ASAP!
There are garages out there (yea, even in Aussie!) that can do it. Try a Holden dealer or if not I've found there are others who have the reader like an auto trans shop.
Any idea what pre empted it ?
Old Jun 12, 2010 | 02:10 AM
filoblazer's Avatar
Pre empted? No idea will do that thanks
Old Jun 12, 2010 | 02:49 AM
kiwiblazer's Avatar
An example, when I had my light come on it was as a result of a hard shift from 1st to 2nd gear. In my case it threw out a P1870 code which was related to a transmission fault, but there could be other issues such as an O2 sensor (on the exhaust) etc. Not all errorsill be as a result of something noticible happening - I don't think.
Old Jun 15, 2010 | 02:26 AM
filoblazer's Avatar
finally found the problem, what said on the computer that there is low pressure on the coolant something like that but its all done now no more engine light on. Has this happen to anyone
filoblazer
Mar 17, 2012 06:18 AM
96Ls4Dr
Aug 8, 2011 06:04 PM
Kendrick2155
Aug 8, 2010 03:08 PM
seanstutts
Nov 16, 2009 09:43 PM
cartunez2004
14
Sep 25, 2009 10:31 PM
