Chevy blazer engine prob need help asap
Old Feb 6, 2012 | 12:38 AM
filoblazer's Avatar
filoblazer is on a distinguished road
Default Chevy blazer engine prob need help asap
Hey guys my trunk not looking to good. Today I was driving suddenly the revs were going up and down and it died. Started it no prob but after a few seconds it back fires rev still going up and down and dies on me. Any idea what's the problem.
Old Feb 6, 2012 | 01:48 AM
Chuk Rhodes's Avatar
Chuk Rhodes is on a distinguished road
Is the check engine light on? If so can you read the codes?
Old Feb 6, 2012 | 04:05 AM
filoblazer's Avatar
The Engine light is on. It sometimes blinks. Will let u know Once I get the code
Old Feb 6, 2012 | 04:21 AM
Fairly sure blinking means there is a new code. Thats fairly good, as it usually points you in the right direction. Start with the first / lowest number, fix that before worrying about others.
Old Feb 6, 2012 | 05:53 AM
filoblazer's Avatar
Thanks for that info. Hopefully Tomz I'll find the code
Old Mar 14, 2012 | 02:15 AM
filoblazer's Avatar
Found the problem it's the whole distributor needs replacing I think. I pulled the cap off and the rotor was stuffed. Is the shaft on the dizzy suppose to move around or be solid? Cuz it's kinda loose. One more think are all distributor of a blazer 99 to 01 model all the same?
Old Mar 14, 2012 | 05:57 AM
pettyfog's Avatar
You're correct.. should be no wobble, little spin available.
Best way to find that out is to look up other year model part # and compare them to yours.
Rockauto{dot}com does one better; click on the part number and it shows all models with same fit.
Old Mar 17, 2012 | 06:18 AM
filoblazer's Avatar
Distributor replaced and now car is running good
LSpoweredStepside
Sep 30, 2013 09:22 PM
96Ls4Dr
Aug 8, 2011 06:04 PM
mcanter23
Sep 5, 2010 09:36 PM
nasir
Nov 10, 2008 06:13 PM
offroadin974wd
Jan 22, 2007 10:37 PM
