01 Blazer has heat only when run @ high rpm's
Old Oct 30, 2011 | 02:36 PM
242176's Avatar
242176 is on a distinguished road
Default 01 Blazer has heat only when run @ high rpm's
Engine temp is normal at all rpm's, I so I don't suspect a thermostat prob.. thinking blocked heater core? No coolant leaks anywhere..
Old Oct 30, 2011 | 02:41 PM
pettyfog's Avatar
And if you open the radiator cap -WHEN COLD - the coolant is all the way to top?
Old Oct 30, 2011 | 02:51 PM
242176's Avatar
Yeah, coolant levels are all good, in the rad & the reservoir tank.
Just this week out of the clear blue the heat is acting up.
If run at high rpm's the heat works great, but when run at lower r's it cools right off.
Old Oct 30, 2011 | 03:06 PM
pettyfog's Avatar
If it goes from cold to hot in a couple seconds, that is not a good sign. If it's hot as it used to be when it is hot, your core is not plugged.
Does it stay hot while accelerating to highway and when passing? If it starts cooling down then, perhaps vacuum actuator problem.
Try this:
Drive the truck around town, till the temp hand shows normal temp for a few minutes. Then shut it off and watch the reservoir for bubbles.
Old Oct 30, 2011 | 03:17 PM
242176's Avatar
The engine temp is stable, at any running speed whether it be fast or slow.
If I drive with rpms over 2k rpms, the blower heat is great. If I upshift so the rpms drop to below 2k, then the heat from the blower motor cools down in a matter of seconds.
Old Oct 30, 2011 | 07:41 PM
242176's Avatar
All's good- low radiator level, thought it was full, but not (my bad!). Problem solved, replaced the rad cap & thermostat anyway. Thanks for the advice!!
Old Oct 30, 2011 | 10:12 PM
blazer chris's Avatar
blazer chris is on a distinguished road
Check for coolant leaks!! It shouldnt just go low like that!!
mcdevin1973
Oct 5, 2014 02:52 PM
rsvensson
14
Feb 9, 2014 06:01 PM
ek72
Aug 22, 2011 09:42 AM
helo
Oct 7, 2010 10:38 PM
mcaanda
Dec 15, 2009 08:31 PM
