01 Blazer running rough
Well my check engine light came on they other day and read codes for the MAF Sensor and EGR Valve. So I cleaned them both, check engine light remained on. It's been running fine for the past 2 days but today I got home and put it in park and it seemed like it wanted to die. So I revved it up a bit and when the RPM's came back down it went to around 3-400 and almost died but then went to 600ish and ran a little rough. So I shut the truck off and tried to start it again and it cranked a few times and I had to give it gas to start, but it always used to start up right away. So I tried again and it had to crank for a few times and it started but is running rough. I'm thinking that since the check engine light remained on even after a very good cleaning that the problem may be the EGR Valve or MAF sensor itself. Anyone have a clue? Thanks. Mitch
I cleaned the EGR Valve with Carb Cleaner and used a Dremel with a wire tip to get just about all the Carbon out of it. Made sure it was dry before re-install.
The MAF Sensor I used the actual cleaner made for it. I cleaned it off gently. Didn't touch the little wires. Didn't seem to be all that dirty.
I did not have the codes cleared. Battery has not died. Not sure how to check fuel pressure. The codes were P0401 and P0101. No I did not clean the throttle body. Thanks for the replies.
I just went out there and she fired right up no problem. 14* F. Idle is 1100 which I'm assuming because it's cold.
Check these threads out and look for things that could cause both codes:
P0101 - Mass Air Flow System Performance
P0401 - Exhaust Gas Recirculation Flow Insufficient Detected
I took it in again today and the EGR Code is gone but the MAF code is still there with a new one. P0410. I'm assuming it may be that sensor you were talking about in the throttle body Swart? Also when I went out to leave it had to crank a few times again.
blazerguy22
Nov 14, 2013 11:50 PM
ksimpson
14
Oct 7, 2013 05:25 AM
lennyblazer
Jun 2, 2007 11:22 PM
93LT
Mar 11, 2006 01:56 AM
