01 blazer starts the dies
Old May 21, 2009 | 03:15 PM
linje's Avatar
linje is on a distinguished road
would it be possible for the old switch to skip a tooth, and thats what started this to begin with?
Old May 21, 2009 | 03:18 PM
I do not believe it is possible to skip a tooth once it is installed.
Old May 21, 2009 | 03:23 PM
linje's Avatar
Is a dying fuel pump something that exhibits this behavoir?
Old May 21, 2009 | 03:26 PM
As I said, your pressures look good from what you reported. You would have to monitor pressure while you have your problem to know for sure. This would require having the pressure gauge connected and visible while the problem occurs.
Old May 21, 2009 | 03:32 PM
linje's Avatar
Thank you, ill hook it up again, but just to clarify, even after the truck stops running
the pressure should not drop below 55 or so psi?
Old May 21, 2009 | 03:49 PM
Correct. Not below 55psi.
Old May 21, 2009 | 04:15 PM
linje's Avatar
Thank you swartlkk for all your time and help.
Old May 21, 2009 | 04:30 PM
linje's Avatar
Im sorry i keep posting, but with key on i get 60 psi, while egine running i get 55 -56 psi, but when it dies it drops to 42 psi, bad fuel pump?
Old May 21, 2009 | 07:10 PM
You should check to see if the fuel pump is shutting off just prior to the engine dying. You can do this by probing the power feed to the fuel pump at the relay. If the fuel pump looses voltage just prior to the engine dying, it is not the pump.
Old May 22, 2009 | 05:00 PM
linje's Avatar
Ok, sorry swartlkk, although i feel like you are quickly becoming my new best friend
the pump does seem to lose voltage as the engine dies. I've swapped relays with a good one, but diddn' seem to matter. What else could trip the power to the fuel pump?
