01 blazer won't start
Old Jan 25, 2007 | 03:42 PM
cjs030901's Avatar
cjs030901 is an unknown quantity at this point
Default 01 blazer won't start
2001 blazer wont start, 140,000 miles V6 4x4- replaced fuel filter, dribbled gas into the air intake and still wont start, it stopped running the end of november, din't drive it for about a week but kept trying to start it, then i tried- andfired right up, then about 2-3 weeks later after driving it daily,went to start it and nothing, so we replaced the fuel filter and nothing, dribbled gas in the intake and nothing...any ideas
Old Jan 25, 2007 | 05:15 PM
Icarus76's Avatar
Icarus76 is an unknown quantity at this point
Default RE: 01 blazer won't start
fuel pump?
Old Jan 25, 2007 | 05:26 PM
Dabber's Avatar
Dabber is an unknown quantity at this point
Fuel pump usually works or it don't. I don't think there is a in between
Old Jan 26, 2007 | 01:44 AM
Hanr3's Avatar
The fuel pump can work and not supply enough fuel pressure. These engines require either 13psi (TBI) or 60psi to start the engine. Once running it will drop 2-3psi (TBI), 8-9 psi for the rest. Just becuae it is running doesn't mean it is suppling enough fuel pressure to start the engine.
I gather the fuel pump whines for a couple seconds when you turn the ignition key.If not the problem lies elsewehere.
Old Jan 26, 2007 | 12:12 PM
cjs030901's Avatar
after we replaced the fuel filter we turned over the key and yes there is a humm (fuel pump turning on) but if you go to start is is like it is not catching, we also checked the bleeder hose at the back of the engine up by the dash and there is fuel that squirts out, where do I hook up the fuel pressure gauge to test the fuel pump pressure? thanks for your help
Old Jan 27, 2007 | 12:02 AM
Hanr3's Avatar
Where you gotthe fuel to squirt out. Its a scrader vavle, like the ones used on tires, or the air conditioner.
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
