01 Blazer - WTF!! not running, tough cookie. Please help???
Old 02-09-2014, 06:02 PM
iian's Avatar
iian is on a distinguished road
I was chasing a 507 code for a while. Found out it was the pcv grommet. Replaced with a AC Delco pcv valve and grommet from the dealership. No more 507 code for a week and smooth running.
  #22
Old 02-09-2014, 06:26 PM
rockp2's Avatar
Originally Posted by jgbuzzin
I will for sure get the remaining ignition components in the Delco brand, but not for a few weeks.
^^Yeah...save your pennies. I couldn't believe how much those Delco wires are.
  #23
Old 02-09-2014, 08:37 PM
The PCM uses the IAC to create a vacuum leak which increases idle speed. When the IAC retracts, it opens a passage in the throttle body that allows a portion of inlet air to bypass the throttle plate, this is what causes the idle rpm to increase. If the throttle stop screw is backed out all the way, and the throttle plate is fully closed, and it still idles too high, either the IAC is not fully extending to seal off the bypass, or there's a vacuum leak. Those are the only two things that will increase the idle speed.
  #24
Old 02-12-2014, 04:55 PM
jgbuzzin's Avatar
jgbuzzin is on a distinguished road
If my $$$$ allows, I will grab a throttle body from a junk yard, i found one called speedway in illinois, and i know they have the same year same equipped vehicle. for now, it runs good, the idle bothers me, and the lack of a cat on there, not sure yet. have not welded it back into place yet.
blazerhelp01
03-30-2015 09:36 PM
kgpace
09-16-2009 01:57 AM
dave selfridge
Suspension Tech
07-04-2009 03:48 PM
Paul96blazer
12-16-2007 10:21 PM
cwiththehad
11-26-2007 05:21 PM
Quick Reply: 01 Blazer - WTF!! not running, tough cookie. Please help???
