01 hvac fuses blowing in frigid temps
Old Jan 15, 2009 | 08:00 PM
djwilliams's Avatar
djwilliams is an unknown quantity at this point
Default 01 hvac fuses blowing in frigid temps
Last night I started the vehicle at work in -5 F temps, and the blower setting was on 4. Battery somewhat slow to start vehicle and the 30A fuse burned out. I changed it at home. Blower worked great. Now tonight blower motor a no go.
Thanks in advance,
Don
Old Jan 15, 2009 | 08:51 PM
Default RE: 01 hvac fuses blowing in frigid temps
*Moved to 2nd Gen Tech*
This fuse only services the blower. How the power is used depends on the HVAC system you have. IIRC, RPO C42 is a heater only (no ac), RPO C60 is A/C & Heat, and RPO C88 is the Auto climate control HVAC system.
Here are the three electrical diagrams (since C42 is not very common and the blower controls are the same as C60, I will skip that one):
RPO C60
RPO C88
Does the fuse blow only on high or does it blow on any of the other settings? The relay is the only thing responsible for the high setting and no current goes through the blower motor resistor block for the C42/C60 system. For the C88 system, the blower motor control module is responsible for it all.
nineteensixtycaddy
Sep 12, 2010 08:54 PM
SDimeBlazerlady
Dec 2, 2006 10:53 PM
XBlazer01
Jun 20, 2006 05:18 AM
WIKKID1
Jan 6, 2005 03:48 AM
WIKKID1
Dec 21, 2004 06:36 PM
