02 2WD Blazer Persistent Misfire, Looking for Fresh Ideas
Old Yesterday | 12:53 PM
Just an interested observer on this thread, but dang George, you are amazing. I love your approach to diagnosing and I learn something from so many of your posts! Thanks!!
Old Yesterday | 02:45 PM
GeorgeLG's Avatar
Thank you Christine, I am glad to be part of the team
George
Old Yesterday | 08:44 PM
Jacoby -_-'s Avatar
Jacoby -_- is on a distinguished road
Alright, once more as requested.
1. Cam retard is dead on 0 after doing a little adjusting and re-checking once bolted down.
2. Pulled the crank sensor and cleaned it up, absolutely no damage on it or the wheel teeth, I thought about touching the timing chain with something while the hole was open but I completely forgot to do so before re-installing
3. I performed drop cylinder both at the distributor and plug wires, results below
Minimum idle with all cylinders plugged in: 700RPM
Minimum idle with cylinder 3 unplugged: 680RPM
Minimum idle with cylinder 5 unplugged: 640RPM
4. I haven't pulled them since the distributor install on Wednesday but I can do so soon and send over some pictures
5. Fuel trims provided before are ranges, minimum~maximum, should have clarified before
7. Got some measurements at ambient
ECT: 68F
IAT: 69F
MAP: 29.8Hg
All 02 Sensors were bouncing between 430 ~ 450 mV
LTFT1%: 12
LTFT2%: -1
8. I know you didn't request it, but I know that a vacuum test can tell a lot about valve health, so I attached a gauge to the booster line from the manifold, video attached, tested at idle and 2400 - 2600 RPM.
JantzenDay
Mar 16, 2023 11:08 AM
Tony Brown
Feb 3, 2016 09:00 PM
theblaze1
Aug 4, 2015 05:43 PM
rrk03300
Nov 15, 2012 10:29 PM
dbftw
Oct 13, 2011 11:51 PM
