Cylinder 5 Misfire Problems - 1998 Blazer 92k Miles 4.3L V6
Old Jan 16, 2023 | 06:09 PM
JantzenDay's Avatar
JantzenDay is on a distinguished road
Default Cylinder 5 Misfire Problems - 1998 Blazer 92k Miles 4.3L V6
Looking for guidance with a cylinder 5 misfire issue. Often it will throw a multiple cylinder misfire after throwing 2 or more cylinder 5’s. It seems to only happen when holding somewhere around 2,800-3,200 RPM for steady amount of time, say going up a long steep hill or passing someone on the interstate. Runs, idles, and starts great other than this issue.
I have installed new spark plugs, new wires, a new distributor cap, and a new distributor rotor. Could this be a fuel issue? It has a new fuel pump that is a year or so old, and a new fuel filter that is around 4 months old. Hoping it isn’t an issue with my spider injector.
Old Jan 17, 2023 | 05:41 PM
GeorgeLG's Avatar
How does the truck run?
You have a P0305 code or you see misfires on a scanner in live data?
Have you adjusted CMP retard?
Have you performed a fuel pressure leak down test?
George
Old Jan 24, 2023 | 09:18 AM
jimmy3221's Avatar
jimmy3221 is on a distinguished road
Default Check fuel pressure
I’d definitely check fuel pressure in it first
Old Mar 16, 2023 | 07:56 AM
JantzenDay's Avatar
George
The truck runs great, I don’t even notice the misfire until it throws a check engine light.
I am getting a P0305 code from a scanner.
I have also begun to get cylinder 4 misfire alongside the multiple cylinder and cylinder 5.
I will check fuel pressure next and go from there.
Thanks!
Old Mar 16, 2023 | 11:08 AM
GeorgeLG's Avatar
Fuel pressure is a great start but you will also need to get CMP retard in spec so you don't start chasing misfire ghosts.
George
plaguedanarchy
Dec 11, 2025 08:59 AM
Tcannon408
Dec 27, 2020 01:41 PM
benjaminellwood
Aug 20, 2013 08:24 PM
Jimmy_Blazer
Feb 16, 2013 01:03 PM
dbftw
Oct 13, 2011 11:51 PM
