02 4dr fuel issue/ lonnnnnnng crank
Old Nov 23, 2012 | 06:11 PM
jimhens82's Avatar
jimhens82 is on a distinguished road
Default 02 4dr fuel issue/ lonnnnnnng crank
Blazer is tough to start and my pressure readings aren't exactly where they need to be 50 psi keyed up and takes forever to get goin, but if hook cables to it to jump it it starts a lot easier its got an airtex in it ... And it does leak down quick within an hour drops to 20 wondering if I should pull the pump and replace or if the regulator is bad since the 02 doesn't have a vac line to check it is there another way also I know that delco pumps are the way to go but the airtex was all I could get In a pinch, what ya'll think ??
Old Nov 23, 2012 | 06:25 PM
Micscience's Avatar
Micscience is on a distinguished road
Is it an 02 or an 01? is it the SCFI engine? I can check but I'm just lazy. When you hook the cables does it start normal or still a little bit sluggish? how is your battery voltage? if you have a leak it can be your fuel pump check valve but you have to isolate where the leak is in your fuel lines either in the back half of the line or up front where the regulator and injectors are.
Old Nov 23, 2012 | 06:35 PM
jimhens82's Avatar
02, battery voltage is fine it still starts hard with cables but not as bad, I'm leanin towards the regulator once it fires and runs it drives fine but it could b pump and reg ?
Old Nov 24, 2012 | 07:57 AM
spittybays
Guest
Posts: n/a
This is one way to tell if its the reg or the pump but you need a friend. You pinch the feed and return line with it pressurized and see if you still have leakdown. You can also deadhead at the filter.
Old Nov 24, 2012 | 09:51 AM
50lb_cat's Avatar
Or just look down the throttle body, if you see goldish color and it looks really clean, you know its the reg or injectors leaking. It should look really black.
Buddykitchen
Dec 10, 2016 06:37 PM
jimhens82
Mar 28, 2013 06:23 AM
jimhens82
Sep 11, 2012 12:42 PM
majik211@yahoo.com
Aug 23, 2012 04:21 PM
g_mike
Aug 22, 2010 02:46 PM
