'02 Blazer , mystery broken black wire near battery
Old Dec 1, 2017 | 12:37 PM
Snap-Off's Avatar
Snap-Off is on a distinguished road
Default '02 Blazer , mystery broken black wire near battery
'02 Blazer , mystery broken black wire near battery...Is it safe to assume any 14,16, or 18ga black wire near the battery should be a ground wire? Just got this blazer , while going over it found a broken off black wire near the battery? Any ideas?
Attached Thumbnails '02 Blazer , mystery broken black wire near battery-blazer-wire.jpeg
Old Dec 1, 2017 | 12:42 PM
Snap-Off's Avatar
It goes down along the passenger side frame towards he firewall..I haven't gotten underneath to have a look yet.
Old Dec 3, 2017 | 04:30 PM
Mike.308's Avatar
This wire looks way too short to go directly into a battery clamp. I'd suggest You to look for the place it could be going to (another part of a wire?). Mines Blazer battery wiring has been reworked before I bought it, so I cannot say.
If You decide not to wait for other replies and give it a try - be sure to use a fuse with the line. Just in case.
Old Dec 3, 2017 | 05:01 PM
GeorgeLG's Avatar
There are three black wires connected to the battery:
G106: Right side frame rail in front of right front wheel
G107: Right front of engine block
G108: Right of radiator support
Find the other end so that we can find where the broken end belongs
George
Old Dec 3, 2017 | 05:55 PM
Mike.308's Avatar
There is something that disturbs me. The stripped end. Too regular to be stripped off accidentally. I'd check with a continuity meter if the wire isn't already connected with a ground signal. Maybe the wire was soldered or connected to some plug or harness? A light maybe? I would check the nearby connectors too.
Old Dec 3, 2017 | 08:10 PM
Snap-Off's Avatar
Thanks for the replies all. I checked continuity to ground and there is none. I am going to probe the wire with KOEO to see if there's any voltage. I also really need to get up under this thing to see if I can track down the source of this wire.
Thanks for the input..
teamrojas
Mar 28, 2015 07:52 AM
boogie1077
Nov 7, 2013 03:01 PM
R A N D A L L
May 24, 2012 08:59 AM
FlatTopFoley
Feb 10, 2009 08:21 AM
Thor_449
Apr 14, 2008 08:18 PM
