02 Starting Problem
Old Apr 15, 2009 | 12:54 PM
shaunbrown1979's Avatar
shaunbrown1979 is on a distinguished road
Post 02 Starting Problem
So I was driving and in motion when my blazer died. 120,000 miles on it and I have owned it a year. I listen and pay very close attention to it along with basic maintenance on my ride. Tried to start it. It will crank and turn but wont start. The belts turn but nothing. Normally when I turn the key, I can hear the fuel pump kind of wine and build pressure and it starts right up. Now I dont hear any wine when I turn the key. Is it safe to assume its time to replace the pump/filter? Any tips for replacement would be appreciated. The truck is safe in front of my work now and I plan on doing the work with some buddies in the parking lot. Thanks for the info!
Old Apr 15, 2009 | 01:37 PM
1995 Blazer's Avatar
1995 Blazer is on a distinguished road
before you go through the trouble of dropping the tank check fuses and the relay because bolth of them are alot easier and cheaper to replace but most likey is gonna be the pump
Old Apr 15, 2009 | 01:42 PM
Had someone check the fuses and relay. They said that was okay. Looks like I may have to drop the tank. Let the fun begin
Old Apr 15, 2009 | 01:48 PM
im dropping my tank today i changed my pump and the damn thing was defective doesnt put out enough pressure
Old Apr 15, 2009 | 02:56 PM
Wow that sucks. I can only hope it goes smooth. I am getting some quotes today and buying the part tomorrow. Tomorrow should be interesting...
Old Apr 15, 2009 | 03:11 PM
rriddle3's Avatar
While it's a good chance that the pump is the problem, before I went to the trouble of dropping the tank, I would diagnose it with a pressure check and follow the flowcharts in this post. If it turns out to be the pump, do yourself a favor and get an AC/Delco unless you like doing the job again sooner rather than later.
Old May 4, 2009 | 06:08 PM
Well I got it all done... Dropping the tank was not fun, especially since the fuel lines are only a few inches longer than aboslutely necissary lol. The pump was marked wrong so I had to go by instinct on the order of the fuel lines. I think they only fit one way anyways. The fuel filter was completely plugged so now I know why the pump went out. Thanks for all the help!
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
mickey2001
Mar 13, 2006 11:51 AM
ghassell
Feb 6, 2006 09:51 PM
blazin97
Jul 9, 2005 03:32 AM
