03 Blazer hesitation issue
Old Sep 3, 2009 | 01:53 PM
hofford's Avatar
hofford is on a distinguished road
Default 03 Blazer hesitation issue
Hello, great forum here! I have spent a while browsing around and there is some great information to be found!!
I have searched the forum for this issue I am having on my Blazer but didnt come up with anything that has similar symptoms. Basically when the truck is just started it doesnt want to move, I put the hammer down and it seems like it wants to die then all of a sudden it will take off like a bat outta hell (Which it should since the i've got 'er to the mat). It only happens when the truck is cold (not physically cold, but hasnt been running) once it warms up it is fine but gets awful gas mileage. Once I went to pass someone on the highway and it did it then, but hasnt since. It is a 4.3l 4x4 LS 4door, 160000km.
Where should I start? Tried injector cleaner, premuim gas, new plugs.
Also I knwo this really doesnt belong here but can I run 30" tires without a lift, I have measured and think they will fit. and...where in canada is the best place to by a rear lift since I plan on doing the tbar crank and would like to balance it out a bit...
Thanks in advance.
Old Sep 3, 2009 | 02:45 PM
rriddle3's Avatar
Has the SES light been on? If so, did you have the codes read? I can think of several things that might be wrong, the Mass Airflow Sensor (MAF), the Intake Air Temperature Sensor (IAT), clogged fuel filter, failing fuel pump, etc.
Old Sep 4, 2009 | 09:05 AM
hofford's Avatar
SES light on, code shows feul pressure error code (bad cap?)
Thanks!
Old Sep 4, 2009 | 10:06 AM
rriddle3's Avatar
If you have the actual code number please post it. I doubt that a loose gas cap will cause the symptoms you mentioned. It normally is just an emission systems code.
Old Sep 4, 2009 | 03:44 PM
xCHIPx's Avatar
xCHIPx is on a distinguished road
Im haveing the same problem Ive changed the fuel filter and my plugs are new. Their are no codes being thrown But it runs like it has a cork in it.
Ive tryed fuel cleaner still nothin. But could it be my injectors?
Old Sep 4, 2009 | 03:48 PM
xCHIPx's Avatar
Also forgot but mines not an 03 its a 99 but haveing the same problem.
Old Sep 9, 2009 | 07:04 PM
ola's Avatar
ola
ola is on a distinguished road
i have a blazer 2000 , with a similar problem,check ,1)pickup coil,2)module and coil,good luck.
Old Sep 10, 2009 | 09:59 AM
hofford's Avatar
Sorry but which module are you refering to? Thanks
96Blazernut
Dec 3, 2009 11:28 AM
eknox327
Jul 27, 2009 10:00 AM
Emerica2843
Jul 18, 2009 02:29 AM
Weedenski
30
Jun 3, 2009 10:57 PM
shemp01
Dec 18, 2008 04:48 PM
