'03 Blazer key stuck in ignition
Old Feb 26, 2008 | 06:55 PM
tryntofixmykidsblaze's Avatar
tryntofixmykidsblaze is an unknown quantity at this point
Default '03 Blazer key stuck in ignition
My son was driving in the snow last night and had to use the emergency brake to help him stop before he went into his friends parents garage.When he came home later on the key will not come all the way out of the ignition. I read some of the topics on this here But I am very confused. I was able to get the key out by pushing on the brass button inside the steering column. But not sure what happened in the first polace that caused this the key to get stuck. he had power in the truck until he went out there and left the radio on. I am charging the batt. now. But i am hoping to get some info on what to do next to fix this for him so he doesn't get stuck somewhere.
Old Feb 26, 2008 | 07:24 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: '03 Blazer key stuck in ignition
once you charge the battery, try to get it out/or try it again(the key).[8D] I had a 97 just today that had the same issue with a weak battery. After charging, put it back in and whola...worked fine. Let us know. jp
Old Feb 26, 2008 | 07:29 PM
dBsound's Avatar
dBsound is an unknown quantity at this point
We had the same problem with my 2001 today.
We had disconnected the battery, while changing the transmission. The key WILL NOT come out, without a battery.
In what universe does this make sense???
Old Feb 26, 2008 | 07:58 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
It is all part of the shift interlock system, I know it does not make sense, but that is the way that they wanted it to work, I guess!
Old Feb 26, 2008 | 10:31 PM
I got it started and let it run for an hour to charge back kup. when i shut it down same thing it was stuck until I pushed on the brass acuator. I asked my sone if he had hit anything or ran over something that would have caused the issue.he said no. Will it be safe to drive and just use a small screw driver to push on the acuator until I can do better?
Old Feb 27, 2008 | 01:55 AM
RedXBlazer's Avatar
RedXBlazer is an unknown quantity at this point
is it a floor shifter? if so try slamming it into park a few times that normally releases my key unitl i get around to fixing the key release button lodcated at the front of my shifter
Old Feb 27, 2008 | 02:05 AM
thegr81's Avatar
When I pulled my gauge cluster out to put in led bulbs I tried to pull my key out and had the shifter on the column not all the way in park of which I thought it was! Try putting it in park a few times and see if that releases the key!!
Old Feb 27, 2008 | 04:18 AM
Thanks for the info everyone
Old Feb 27, 2008 | 04:30 AM
thegr81's Avatar
No problem let us know if it helps if it doesn't then we can try and suggest another method!!
Old Feb 27, 2008 | 07:51 PM
972DRBLAZER's Avatar
972DRBLAZER is an unknown quantity at this point
try checking your fuses. my truck did the same thing, and it was a fuse. sorry, i cant remember what fuse it was.
Harley-Man
Oct 13, 2016 10:42 AM
stingray74
Mar 5, 2015 08:27 PM
dsevern
May 24, 2012 09:17 PM
dagsler
Aug 10, 2010 08:25 AM
klein
May 5, 2007 04:03 PM
