04 headlight housing. Help needed please!!!
Old Mar 6, 2018 | 05:28 PM
Rayraytonto's Avatar
Rayraytonto is on a distinguished road
Default 04 headlight housing. Help needed please!!!
I read most of if not all threads concering headlights but still can't find my answer. I have an 04 blazer and just can't get the housing to sit correctly. The tabs are in the slots and the holes at top and bottom. But there is still a gap even after messing with the beam adjusters. In order to get the low beams adjusted correctly there has to be a unslightly gap. Also I've noticed that the lows are adjusted even height the brights are not one is a lot lower then the others. Can anyone give me some suggestions or tips to this. Are the housing just wore out at the adjusters or the tabs at the top where those to locking mechanisms are or what thanks in advance this is really bugging me
Old Mar 8, 2018 | 08:13 PM
Usually when you have to adjust them that far to make the beam pattern right, the truck has been in some sort of small accident, bump, or fender bender in the past... A small tweak to the radiator support is all it takes to throw the headlights out of alignment. My father's Sonoma had the same issue. I finally got the beam patterns to even out and point strait, but one headlight just looked way off, didn't line up with the hood or grill very well at all. One day when I was under it I noticed the bumper support bar bent and could tell that someone had loosened all the bolts and wiggled things back into alignment so the damages were less noticeable from the outside...
Another thing that'll cause it is aftermarket headlights that aren't quite made to OE size specs. I have clear lens headlights on my 04 and they are both slightly out of whack compared to the grill and hood, but not too terribly that it bother's me. The beam pattern is level and straight where they're at so I live with it lol
That is the major downside to the headlight assemblies in the S Series body style, the fact that the entire headlight assembly has to be moved and manipulated to change the aim, instead of just moving and adjusting the reflector housing inside the light like most other vehicles... Up side to this is replacement headlight assemblies are less expensive lol
Old Mar 11, 2018 | 08:53 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
You have four tabs that are held in place by the slides. There is also a tab slot in front that is sometimes difficult to get into and could be causing your alignment issue.
chevylife
Sep 11, 2014 11:31 AM
CPLSeraphim
May 31, 2013 08:14 PM
jcw7897
Dec 7, 2010 09:18 AM
Mjseyler
Jan 5, 2010 12:44 PM
skitzobmxr
Feb 9, 2007 07:49 PM
