#15 10amp fuse keeps blowing
I also had the Heater core flushed, my gosh, what a difference! The defrost and or heat will now blow you out of the truck lol!!! I strongly urge anyone this time of year too flush the Heater core, it will truly make a world of difference...
I am happy too report back that the #15 10amp fuse is no longer blowing! I had the front passenger side wheel hub replaced and so far that did the trick... As I stated before, the shop I use said they found no evidence of a short and by replacing that wheel hub seems too have been the problem... All gauges are working as they should and the 3 button 4x4 switch on the dash is doing just fine.
My guess is that you have a dead short in the wiring on the passenger side and during the hub replacement the wires got moved around relieving the ground issue.
I have heard of stranger things happening so good luck and just hope the problem don't come back with a vengeance
go chevy
11-24-2018 07:11 PM
ncpi
07-06-2016 02:32 PM
crags
08-09-2009 08:04 PM
