1995 blazer won't start
Blazer had starter replaced 2 years ago, fuel pump comes on, all lights, bells, and gauges light up, rotor , plugs, plug wires, and distributor just replaced.. turn key over and no sound other than fuel pump kicking on. Any ideas.
check the battery voltage like spitty was saying. also check the cable at the starter and make sure you are getting full voltage through the cable from the battery to the solenoid. if it has had excessive corrosion over time it will follow the wires inside the insulation
wings4kites
Jul 10, 2010 07:28 PM
