1995 Chevrolet Blazer wont idle
Anyone have any ideas on what it might be? The check engine light came on a couple weeks ago, and i had it scanned. The codes say it was just the map sensor. Now 2 weeks later,the vehicle wont even idle. The Blazer quits running as soon as i let off the gas. Any ideas? Thanks for any replies. The Blazer is a 4.3 4x4, and only has 112,000 milesif that matters.
Did you do anything with the MAP sensor after getting the code? Will it keep idling as long as you give it some gas?
ORIGINAL: WolfPack
How do you figure a MAP sensor wouldnt effect idle? You also might want to replace the idle air control valve as a cheap test.
At least pull the IAC valve and clean it. While you are cleaning things, remove the EGR valve and give it a thorough cleaning as well. Use a new, screened EGR gasket when reinstalling it.
And I do not follow your reasoning for not doing anything with the MAP sensor. It is what is responsible for the fuel injection and spark timing in the engine. Sure it could cause a problem when at idle.
ORIGINAL: WolfPack
Yeah I thoughtit had aMAF sensor. Thanks for the diagram. Ill let you all know if that fixed the problem.
chevyblazer9588
11-20-2012 10:40 PM
chevyblazer9588
12-11-2011 02:38 AM
chevyblazer9588
08-23-2011 08:51 AM
chevyblazer9588
06-08-2011 10:28 AM
gdwatson@sc.rr.com
07-22-2009 09:05 PM
