1995 fuel tank question
Old Nov 1, 2007 | 03:00 PM
ronmunch's Avatar
ronmunch is an unknown quantity at this point
Default 1995 fuel tank question
My 16 year old son has a 1995 blazer 4 door with a dent in the bootom of the fuel tank. It is big enough that it affects the reading of the gauge when it is low. I have heard that people have put compressed air into the filler neck and it may pop it out. Any ideas if that may cause any damage to the pump or evap system? Or should I bite the bullet and drop the tankand remove thepump module and push it out with a wood dowel?
Thanks for any input
Thanks for any ideas
Old Nov 1, 2007 | 03:05 PM
Default RE: 1995 fuel tank question
You may also be able to epoxy on something you can pull on to pop the dent. I would not use compressed air on any container not meant to be pressurized.
Old Nov 1, 2007 | 06:44 PM
DlJr82's Avatar
DlJr82 is an unknown quantity at this point
Please correct me if I am wrong but isn't there always some sort of pressure in the gas tank. If there is im sure it isn't a lot.
Old Nov 1, 2007 | 07:04 PM
The tank is under vacuum at all times during operation. This is an Emissions feature to keep fuel fumes from exiting the vehicle.
Old Nov 2, 2007 | 04:02 PM
fred96's Avatar
fred96 is an unknown quantity at this point
i also have the same prob in my 96 4x4 i have a dent in the bottom rear part of the fuel tank it is pretty big and goes in about a 1/2 to 3/4 inch at its highest point could someone tell me if i may have just pinched i in tank line or something or could i have really messed something up as in the fuel pump
Old Nov 6, 2007 | 02:43 PM
fred96's Avatar
bump for this thread
it would really be appreciated if someone had some ideas
thanks in advance
Old Nov 6, 2007 | 07:22 PM
hernandez3674's Avatar
hernandez3674 is an unknown quantity at this point
funny you started this thread because my 97 has the same issue. I am positive its because my local backyard mechanic used a jack to drop the tank to replace the pump. It bothers me to see this also evertime i crawl underneath.. ANyways, what I am did is purchased some 2.5 inch suction cups...a set of three.. I should get to it this weekend. if it works I will let u know...might try adhesive.. also..
Smc
Nov 14, 2013 04:46 PM
zstudna
Dec 31, 2011 10:03 AM
wjdjake
Jul 17, 2011 02:06 AM
Hank3band
Jun 6, 2011 06:44 PM
lacanars
Mar 28, 2011 12:39 AM
