2dr Fuel Tank Vent puking fuel
Old Jun 6, 2011 | 06:44 PM
Hank3band's Avatar
Hank3band is on a distinguished road
Default 2dr Fuel Tank Vent puking fuel
2000 Blazer LS 2dr 4x4 ZR2.
It was 90 degrees and Blazer sat in sun all day with only 1.5 gallons of fuel. I drove it 20 miles then stopped at gas station. I put pump on full blast and tank took 17.7 gallons then stopped. I pumped in another .3 gallons and the pump clicked off again. Then I hear a release of air and fuel near the tank. It puked fuel from what sounded like the top of the tank. I look underneath to see about 1/2 gallon of fuel leaking off the fuel tank skid plate onto the ground.
The Blazer started right up and I moved it into a parking spot. The leaking stopped and the Blazer was running fine, showed full on the gauge. I then drove it 230 miles back home. It runs fine now, no leaking. I just replaced the fuel pump myself 2 weeks ago. I have an intermittent check engine light but it always goes away. Autozone code reader didn't produce any codes.
I think that the fuel tank vent pushed fuel out. Could that be the case?
I can find a vent at either lmctruck.com or Rockauto. Do the 2dr have a fuel tank vent? (Its a steel tank)
sky_blazer
Sep 9, 2018 09:24 PM
lowrolla
Nov 25, 2011 10:15 PM
6lbsledge
14
Jul 27, 2011 08:35 PM
SteveCZ28
May 22, 2010 08:25 AM
jmberman
Jan 20, 2008 10:20 AM
