1995 W Block Cmfi Nut Kit
Old Apr 18, 2010 | 10:03 AM
nineteensixtycaddy's Avatar
nineteensixtycaddy is on a distinguished road
Default 1995 W Block Cmfi Nut Kit
Ok everybody,a fuel spider is technically a fuel injector kit according to parts stores. My question is what part or part number is a nut kit as advance auto and auto zone being stupidified when I tell them I need to replace my nut kit. All help greatly appreciated!!!
Part Number would be best if you got it!!
Thank you!
Old Apr 18, 2010 | 05:11 PM
A few seconds on each website.
On Autozone.com --> Dorman # 55163
On AdvanceAuto.com --> BWD # 28430
Old Apr 19, 2010 | 05:12 PM
Ok.. nut kit numbers helped a ton! Was able to purchase and obtain the same day.
Installed nut kit, installed fuel spider, turned key, checked for leaks, no problems! Installed upper plenum, connectors, vacuum lines, etc etc. Torqued down intake, etc etc.
Fired it up, and... misfire still here.
Pulled all plugs, set on block, checked each for spark from distributor. All are sparking perfectly when starter turned.
And I'm assuming all cylinders are getting fuel, due to new nut kit and spider.
So... what could still possibly be wrong?
grey95chevyboy
Jul 14, 2014 09:50 PM
79MKII
Nov 16, 2012 04:14 PM
midnightmekanik
Oct 8, 2009 08:32 PM
7mmremag
Jul 3, 2009 10:40 PM
lil_blazin
May 10, 2009 05:20 PM
