1996 4 door blazer wont start / urgent pls.
Old Jun 19, 2008 | 03:11 PM
burak sozer's Avatar
burak sozer is an unknown quantity at this point
Default 1996 4 door blazer wont start / urgent pls.
I have a close friend here, he is a mechanic, helping me a lot. He has his customers 1996 4 door blazer with 4.3 engine ( same as mine) , the engine had fuel ( 60 psi continiously, sill over 55psi after I shot the key), has spark ( coil,module,plugs, cap-rotorchanged), crank-cam and chain is fine , crank position sensor has changed, the car still dont start.
Today we had get sick trucks ecm and pluged to my truck started fine, no failure or lights etc, we had plugged the actron 5000 serries hand held scanner, there no failure code etc, but the truck still didnt start.
BTW battery is fine engine is turning but no start....
fuel is ok, spark is ok, electric is ok, air is free, ecm is fine, what else we shouldcheck?[:-]
Also we have aparted the cat and exhaust while working, theres no chance for plugged cat.
your urgent help will really appreciated..
Thanks.
Old Jun 19, 2008 | 07:38 PM
WolfPack's Avatar
Default RE: 1996 4 door blazer wont start / urgent pls.
have you checked the starter?
Old Jun 20, 2008 | 12:38 AM
yes the starter is fine, engine is rewing with it, battery is fine too, we couldnt find anything logical [>:]
Old Jun 20, 2008 | 08:27 AM
rriddle3's Avatar
Have you done a compression test?
Old Jun 20, 2008 | 03:36 PM
Yes compression has tested.
update:
today car has started, the car has previously lpg converted, we had cancelled the lpg option and its fine... previous mechanic has connected the lpg switch to wrong place
thanks for the replies.
Old Jun 20, 2008 | 06:17 PM
rriddle3's Avatar
Well, yeah, that could make a difference.
Old Jun 21, 2008 | 03:32 AM
I beleive if the car has produced for gas, convertion is not good. Especially if the guy doesnt know what he is doing.
Actually, before we discover the lpg switch, i was suspicious about, neutral safety or its power supply, but the engine was reving ...
Anyway , finally it started.
Thanks again.
Nuikala
Nov 1, 2012 11:05 AM
MikeTastic
Aug 8, 2012 04:41 PM
jake5504
May 27, 2011 07:59 PM
tyrant46whtcobra
Sep 7, 2008 08:00 PM
cimbali
May 28, 2006 08:59 PM
