1996 Blazer 4x4 not working! Weird noise in 2wd though?
I have a 96 Blazer 4x4 with the 3 button switch. Recently I've been hearing a grinding / rubbing noise coming from the front passenger side wheel. The noise is ONLY heard while the truck is in 2wd. However when I put the truck in 4hi or 4lo the noise completely goes away. Today I decided to jack my truck up to get all 4 wheels off the ground to test out the 4wd. I can hear the 4hi & 4lo engage. I can also see the drive shaft spinning when the truck is in 4x4 when someone hits the gas. However the 2 front wheels will NOT spin. I was told it could be a bad passenger side wheel hub assembly. But why would it only make the grinding noise in 2wd & not 4wd? Any suggestions on where I can look? I tested the dash switch in my friends Blazer & it worked fine. Thanks!
If you look in the forum you'll see a DIY section https://blazerforum.com/forum/tech-a...e-first-30093/ <----
if you look in there you'll see a wealth of information on any topic or problem you'll likely come across, I recommend taking a read through there........
However, I'll make you're life easy this time
https://blazerforum.com/forum/tech-a...ill-help-7180/
![Stick Out Tongue](https://blazerforum.com/forum/images/smilies/tongue.gif)
Thanks for the links! I will be looking into that today. One more question though. Can a bad passenger wheel bearing cause the 4x4 not to work at all?
It's most likely the vacuum switch on the transfer case. There's a spring loaded ball that gets pushed in when you select 4WD. It's either sticking or stuck allowing the right axle clutch to partially engage in 2WD causing the grinding noise.
![](http://i561.photobucket.com/albums/ss58/cwhook/49315or600-500transfercaseswitch.jpg)
It's located on the driver side of the transfer case, just inboard of the driveshaft yoke and has 3 vacuum lines attached to it. Dorman makes the part (#600-500) and it's also available in their "HELP" line of parts (#49315). It's under $20, most parts stores keep them in stock. It takes about 15 minutes to replace it.
GMC_Jimmy_13
45
09-19-2013 09:47 AM
ryanpip18
03-26-2007 04:18 PM
