1996 Blazer Quetions
Old Sep 30, 2010 | 08:32 PM
TylerNormand's Avatar
TylerNormand is on a distinguished road
Default 1996 Blazer Quetions
The temp gauge stays here when i crank it. I can drive it for 15 minutes and the engine is really hot. I put water in it everyday and by night i have to put more in. Why could it be running hot so quick?
The break light stays on and wont go off. Why is this?
I found this under the drivers side dash it was not plugged into anything. Any clue what it is? My break lights nor blinkers works could it be something to do with that? When i bought this blazer it was used and someone had went through the dash and unplugged the 4x4 i just recently discovered it and plugged it in.
This wire was pushed into the dash and i found it and the was the only place i could find for it to go it is located just under the fuse panel. What is it?
The back hatch wont pop. the button lights up but when i press it it makes no sound or nothing. I figure its the motor has gone bad inside the bottom part. Can you open it with the key i have tried but it wont work it just locks and unlocks the doors.
Please help. I know nothing about cars.
Old Oct 1, 2010 | 11:32 PM
jessie345's Avatar
jessie345 is on a distinguished road
"The temp gauge stays here when i crank it. I can drive it for 15 minutes and the engine is really hot. I put water in it everyday and by night i have to put more in. Why could it be running hot so quick?"
check to see if there are any fluids leaking into your intake manifold. if the intake is wet, that's probably why. Buy a Hanyes manual at Autozone. we just had to replace ours because antifreeze was leaking into it. the plastic seals on the intake had all but broke.
broncoman1532
Aug 26, 2012 11:52 PM
frosajr
Sep 15, 2009 09:48 PM
dobbist
Apr 10, 2005 11:37 PM
thefox1
Apr 9, 2005 07:30 PM
dawne fischer
Dec 21, 2004 12:16 AM
