1996 Blazer torque info
Old Jan 20, 2014 | 04:13 PM
Jesster's Avatar
Jesster is on a distinguished road
Default 1996 Blazer torque info
I am sliding back into place the a/c-PS pump bracket and also the alternator bracket on a 1996 4.3L Blazer. Does anyone know the bolt/nut torque specs for these two brackets to attach to the engine? I have both Chiltons and Haynes and one of them gives the spec for the nut on the bottom bracket off of the PS pump (where you can't fit anything near the thickness of a torque wrench anyway), but I figured these brackets should be torqued correctly on the front fasteners. If I remember from years ago, I just tightened the rear nut off of the PS pump with some loctite.
Is there any place on Blazer Forum that lists all the torque specifications for each model?
On 60degreev6.com there is a list of all the torque specs for my 98 lumina which is very handy and saves a whole lot of time.
Old Jan 20, 2014 | 05:17 PM
Scroll down to the chart that shows type of fastener. Find the bolt diameter and thread pitch. Move across to the right and it shows the torque spec:
http://www.imperialsupplies.com/pdf/...rqueCharts.pdf
rdhoping72
Oct 6, 2010 07:42 PM
thesnowgod
Jan 11, 2010 11:28 PM
Dakota_Don
Jan 4, 2009 08:33 PM
salvy
Oct 30, 2008 03:54 PM
Goatmanof70
Oct 12, 2007 05:56 PM
