1996 chevy blazer
Old Apr 16, 2008 | 03:33 AM
allbusiness2's Avatar
allbusiness2 is an unknown quantity at this point
Default 1996 chevy blazer
I have a 1996 4x4 chevy blazer i am having a problem with it cranking forever. It always starts but it cranks way too long. Any suggestions?
Old Apr 16, 2008 | 05:58 AM
Default RE: 1996 chevy blazer
*Moving to 2nd Gen Tech*
I would recommend a fuel pressure leak down test using a fuel pressure gauge connected to the fuel pressure test port behind the throttle body. Connect the gauge and cycle the key a few times waiting for the pump to turn on, then turn off again, to build the system pressure. You should see pressures between 52psi and 60psi. Then turn the key off and monitor the pressure. If the pressure drops more than 2-3psi, you have a leak somewhere. Most probable is the FPR.
crazycz
Jan 30, 2010 10:47 AM
stevevargas0304
Sep 9, 2009 05:20 PM
pearl0890
Jun 7, 2008 12:51 AM
juliuss
Feb 22, 2007 10:51 AM
dawne fischer
Dec 21, 2004 12:16 AM
