1996 S10 ABS pump/module replacement
Looking for instructions on how to replace Kelsey-Hayes ABS pump/module. I have a bad module so I have picked up a used unit with good module. Can I just replace the (module only) or do I need to replace entire pump/module assembly? If I can get by just replacing module, what is correct procedure to remove and replace? If entire pump/module assembly needs to be replaced then I need correct procedure for that as well?
Thanks
Thanks
oliver586
05-30-2011 01:33 PM
Brian123456789
12-24-2010 03:55 PM
Brian123456789
12-24-2010 03:48 PM
rastoma
11-02-2009 07:04 PM
