1996 starter problem
Old Jan 10, 2006 | 04:01 PM
brownee's Avatar
brownee is an unknown quantity at this point
Default 1996 starter problem
my remote starter works fine but I get that grinding sound just before it turns over. The kind of sound you get if you keep turning the ignition key after the truck has started. Is the remote starter wrecking my starter? should I stop using it?
thanks
Old Jan 11, 2006 | 11:30 AM
Hanr3's Avatar
Default RE: 1996 starter problem
By remote starter, you mean you have one of those fancy keys where you can start the truck from like 50 feet away?
Have you tried starting the truck with the key in the ignition to see if it makes the noise?
Old Jan 11, 2006 | 11:41 AM
Is there an adjustment on the rpm at which it will deactivate the starter, possibly a running rpm adjustment. It would be something that once the remote starter controller sees like 500rpm, it will deactivate the starter. The reason why I ask is because if there is such an adjustment, it may be set too low so even after the engine has started, if it faulters even the least little bit, it will attempt to start the engine again.
Old Jan 11, 2006 | 12:03 PM
brownee's Avatar
Thanks for putting me in the right direction. I will find out if there is a RPM adjuster.
jdmmario
Oct 25, 2014 06:25 PM
mafiaboy01
Oct 3, 2009 10:52 PM
EASTBAYBLAZER
May 10, 2008 02:31 AM
GMdesigner
Jun 22, 2007 12:02 PM
gntlhwkj
Jan 10, 2006 02:16 PM
