1997 blazer airbag help
Old Sep 12, 2011 | 10:27 AM
jonnicole's Avatar
jonnicole is on a distinguished road
Default 1997 blazer airbag help
I'm trying to locate the Diagnostic Energy Reserve Module on my 1997 S-10 Blazer. I looked under the LF seat and under the center console behind the shift lever, but I don't want to cut up my carpet without an idea of the location. Thank you.
Old Sep 12, 2011 | 10:50 AM
The DERM is located behind the passenger side kick panel on the 96-97 s-series trucks. Check out the attached schematic.
Old Sep 12, 2011 | 11:06 AM
jonnicole's Avatar
Default Thank you very much
Will I need to take it somewhere to have them set it to my vehicle or can I replace it plug an go. I am aware of how to disable the SIR system per the Haynes manual. Fuse, connector under steering coloumn.
Old Sep 12, 2011 | 12:06 PM
If you disconnect the battery and wait like 30 minutes, you will disable the SIR system as well.
It should be plug-n-play. You should not have to get anything programmed.
Old Sep 12, 2011 | 12:20 PM
jonnicole's Avatar
Default 1997 airbag
Thank you for your help.
Old Sep 12, 2011 | 12:25 PM
No problem.
*Moving to 2nd Gen Tech* - Just realized this was not in the proper section.
Old Sep 21, 2011 | 07:32 PM
jonnicole's Avatar
Default 1997 airbag light
Thank you for your help, I ended up having to replace the clockspring also, but that took care of the airbag light. The vehicle got inspected.
showteam2008
Sep 23, 2012 10:24 PM
81malibu350
Jul 18, 2012 01:29 PM
LRV31
Oct 5, 2011 03:46 PM
CNYCountryKidd
Sep 16, 2010 06:37 PM
aaronjohn20
Mar 21, 2008 07:00 AM
