1997 Blazer - blend door moves to defrosters on acceleration/load
Old Oct 23, 2015 | 03:07 PM
1997GreenBlazer's Avatar
1997GreenBlazer is on a distinguished road
Default 1997 Blazer - blend door moves to defrosters on acceleration/load
I have a bizarre issue that I can't seem to figure out on my 97 Blazer
When the truck accelerates or the engine is under load (going up hill, etc) - no matter what the control **** is set on - the blend door moves all ventilation to the defrosters.
I checked the vacuum line routing and even replaced the round canister that mounts to the hood (old one broke the inlet nipple). I even checked the vacuum lines in the interior.
What am I missing?
Mitch
Old Oct 24, 2015 | 03:29 PM
Aeromaster's Avatar
Aeromaster is on a distinguished road
The way I understand this is that as engine load increases manifold vacuum decreases. The vacuum accumulator in the fender helps to maintain vacuum to components such as blend doors during acceleration (load). There is also a check valve in line with the accumulator. A leak in a vacuum line and/or a missing check valve may cause the blend door to move to the default position when vacuum is lost.
Old Oct 24, 2015 | 04:18 PM
newguy's Avatar
def a vacuum issue
bubba14731
Sep 10, 2012 12:19 PM
duswang
Jun 23, 2011 02:18 PM
ScottECU
Apr 7, 2010 11:37 AM
NTL1991
Jan 10, 2009 11:22 PM
coplinb
Jan 22, 2008 06:28 PM
