1997 Blazer blinkers do not work
1997 Chevy Blazer blinkers do not work . They turn ON but do not blink
RE: 1997 Blazer blinkers do not work
make sure there aren't any burned out bulbs.
You may need to replace the relay. But yeah, check your bulbs first. If you do not have the towing package, then your relay is a load sensitive relay. Take away the load (ie blow a bulb) and it won't blink...
yes...check bulbs first because if one is out it messes up everything..but if not...then yea...itll the flasher located DIRECTLY behind the cigarette lighters. You have to remove the bottom part of the dash...its sorta hard to get to, but not too bad at all...it will kinda look like a short little dark plastic "oil filter" kinda...its about golf ball size...u just pull it out and pop the new one in...make sure u take out the right one because there are 2 different ones side by side. i think its on the right
jonlandeinthemud
06-08-2011 10:09 PM
