1997 blazer keyless entry/pwr dr locks dont work
Old Sep 7, 2008 | 12:40 AM
civickid's Avatar
civickid is an unknown quantity at this point
Default 1997 blazer keyless entry/pwr dr locks dont work
On a dead short in pwr dr lock system on 97 blaze. The power accessory circuit breaker A keeps tripping. Anything common, can anyone tell me where splice S263 is. THanks
Old Sep 7, 2008 | 09:26 AM
Default RE: 1997 blazer keyless entry/pwr dr locks dont work
Start by disconnecting the RKE module (should be above the driver side hush panel under the dash). If that stops the circuit breaker from tripping, you have a faulty module.
Old Sep 7, 2008 | 04:11 PM
civickid's Avatar
Thanks for the reply.According to the information I am using, thekrmis powered up by courtesy fuse #2 not circuit breaker A. Is my source wrong?I tried disconnecting the keyless remote entry module and the short was still present. From the information I have I started disconnecting everything on the circuit breaker A. Door lock switches, door lock relay, left seat motor and left seat lumbar support. With the connector for the lumbar support underneath the drivers seat disconnected the short was gone. I am gathering to fix this short the seat has to be removed? Thank you
Old Sep 7, 2008 | 04:17 PM
civickid's Avatar
here is a pic of the connector
Old Sep 7, 2008 | 04:49 PM
Sorry, yes, you are correct. For some reason the schematic I pulled up was for a 98 instead of a 97. If you have found the source of the short, then you need to focus on the lumbar support. It is likely that a wire has rubbed through under the seat and is shorting to the seat frame. To make sure that your problem is in this part of the circuit, try plugging everything else back in. If the circuit breaker still holds closed, then you have found the source of the issue.
In order to narrow it down further, you will likely have to remove the seat.
Old Sep 7, 2008 | 11:42 PM
civickid's Avatar
Yeah its definetly in the lumbar switch circuit. I will pull the seat out this week and have a look
Barbara
Oct 14, 2011 04:29 AM
Bonsee
Apr 19, 2011 08:03 PM
richyboy5225
Feb 1, 2011 10:25 PM
regulator71
13
Feb 10, 2009 05:51 PM
BLAZINBlaZer98
Mar 1, 2005 10:53 PM
