1997 Blazer no start, PCM?
Old Jan 29, 2023 | 05:01 AM
tosch's Avatar
tosch is on a distinguished road
Default 1997 Blazer no start, PCM?
Hi,
I just bought a Blazer 97 which is not starting only cranking.
In the dash there is no SES or Check Gages coming up on ignition. Also there is no 12V at the fuel pump and the fuel and oil pressure gauges are maxed out.
Is it right that there is only one fuse box on the driver side in the Dashboard? I looked everywhere to find the fuel pump relay but didn't managed it.
The idea it could be the PCM is that the guy from which I bought the Blazer gave wrong start up to the battery and crossed the poles.
Hope someone has an idea on that.
Kind regards,
Torsten
Old Jan 29, 2023 | 09:11 AM
tosch's Avatar
found it:
it was disconnected.and so the PCM got no power.
Old Feb 5, 2023 | 09:04 AM
tosch's Avatar
Hi,
so now it starts but don't want to take any gas. If I hit the gas pedal it dies.
See ther video here:
I changed till now:
Distributor cap
Ignition Sparks
Irkinition Cables
Fuel Pump
Fuel Pump Lines
Fuel Filter
ICM
EGR
TPS
Any other odears ?
Kind regards,
Torsten
Old Feb 5, 2023 | 12:34 PM
GeorgeLG's Avatar
Lets start with do you have any codes? Do you have scanning capability that can read live data?
George
Old Feb 6, 2023 | 03:07 AM
tosch's Avatar
Hi George,
no codes. I only have a OBD2 Scanner which doesn't fit.
I think it's OBD1, so I can bridge some contacts?
I can get a used PCM, do you think that would help?
Kind regards,
Torsten
Old Feb 6, 2023 | 06:06 PM
GeorgeLG's Avatar
A 1997 Blazer uses ODBII, what does your DLC connector look like?
The PCM is almost never the issue. That said, a replacement needs to be flashed to the vehicle configuration unless it is a prefect match to the current truck.
George
Old Mar 24, 2023 | 04:47 AM
tosch's Avatar
Hi,
sorry for late answer. I finally found the issues:
- Injection Spider was leaking from 4 poppets
- Vacuum Leaks from Intake Manifold
- Vacuum Lines were missing
- Cat was totally clogged.
Now it's running fine.
Thanks for your help George.
And yes for sure it's OBD2, should get some Software to get Live Data.
Kind regards,
Torsten
norah-marie
Mar 26, 2022 11:08 PM
Myblazer2000
16
Aug 25, 2013 01:49 PM
drummerdude84
Jan 7, 2011 01:18 PM
mfd70
Dec 5, 2009 04:20 PM
sword2269
Nov 27, 2009 11:23 PM
