1997 blazer....put in new engine, no power and key stuck in ignition
Old Aug 9, 2010 | 01:09 PM
dagsler's Avatar
dagsler is on a distinguished road
Default 1997 blazer....put in new engine, no power and key stuck in ignition
Bought a 97 blazer and dropped a new engine in it. Now the vehicle has no power....they key is stuck in the ignition and it will not go into any gear...had to remove linkage to tow. It gets power to alternator, battery, and ABS fuse, but that's it. It has a remote start system on it, but no remotes (lol). Anyone have any ideas?
Old Aug 9, 2010 | 02:02 PM
whyteb0y's Avatar
whyteb0y is on a distinguished road
Is it a factory or aftermarket remote start system? If it's aftermarket, I'd try unhooking that and see if that does anything. Do you have power to like the injectors, assuming it's fuel injected?
Old Aug 9, 2010 | 02:04 PM
dagsler's Avatar
i believe its aftermarket as I don't think they put them in standard in 1997. The only 3 things that show power with a tester are the 3 listed above....battery, alternator, and ABS fuse in fusebox. Nothing else shows power.
Old Aug 9, 2010 | 11:15 PM
hoosierhilljack's Avatar
hoosierhilljack is on a distinguished road
The key problem can be solved if it is in park. Have the same problem with my 97. I popped out a cap on the bottom of the steering console just below the key. (It's below the steering wheel where the wheel tilts on the plastic cover) Use a screwdriver and push up the "plunger" and my key rotates back to where it can be removed. Dunno what causes it, I replaced a key cylinder thinking it would help to no avail. I have a friend with a Pontiac Grand Prix has the same problem too. Must be inherent to GM. Hope it helps get the key out at least.
Old Aug 10, 2010 | 08:25 AM
dagsler's Avatar
hahaha....funny thing. feel like an idiot. I inherited vehicle after someone else put new engine in it and could get no power to it. They gave up. Figured it out yesterday...lol...positive wire on alternator was hooked to negative post, thus grounding out entire car. No wonder I had power to starter and that was it....never thought to look there. Moved wire and fires right up.....nice simple fix.
Harley-Man
Oct 13, 2016 10:42 AM
dsevern
May 24, 2012 09:17 PM
Woods1478
Apr 25, 2008 08:57 PM
tryntofixmykidsblaze
Feb 27, 2008 07:51 PM
klein
May 5, 2007 04:03 PM
