1997 Start problem, this ones tough!
Old Sep 12, 2009 | 12:35 PM
kgpace's Avatar
kgpace is on a distinguished road
Default 1997 Start problem, this ones tough!
Hello Forum. I have a 1997 Blazer that tries to start but won't. This problem basically just started. Sure need some help with this. Here is the situation:
1- Cranks, tries to start, plugs are wet.
2- No DTC set.
3- Spray a small amount of ether and engines runs and will restart and is drivable. After about 6 hours of sitting, engine does not start again.
4- Checked fuel pressure at 60 psi and holds with very little if any leak down.
5- Checked h2o, at , map, maf, and o2 sensors, checked good.
6- Check coil, wires, cap, all have been replaced earlier.
What is so puzzling is that there are no codes and once it starts it runs fine. We have 2 Blazers with almost the exact same problem. Is there something that is a common failure for these symptoms for this model year? Any suggestions?
Thanks.
Old Sep 12, 2009 | 12:52 PM
midnightmekanik's Avatar
midnightmekanik is on a distinguished road
I would check the ignition switch... Apparently they are known to go funky on you lol.
Old Sep 16, 2009 | 01:57 AM
old skool luvr's Avatar
how does spraying ether into the engine, get around a bad ignition switch problem? have you checked the fuel regulator kgpace? also, does the same effect happen with gas? (does pouring some fuel onto the throttle body help it start?) i know the pressure is supposed to be 60-65psi for the fuel pump (and you test showed this), but.........how long did you leave the gauge presurized for any possible leak down?you could also have a bad fuel pump that's not showing up right away (possible there is a leak in the system somewhere too).
rickmfromnh
Sep 1, 2011 09:22 AM
stevo
May 18, 2010 11:33 PM
dave selfridge
Suspension Tech
Jul 4, 2009 03:48 PM
Paul96blazer
Dec 16, 2007 10:21 PM
cwiththehad
Nov 26, 2007 05:21 PM
