1998 4x4 not working right
Old Feb 17, 2013 | 02:05 PM
  #21
Irish07's Avatar
Irish07 is on a distinguished road
Originally Posted by Chris Jessee
This is my daily driver, 177,000 miles on it. Runs great. Getting new upper and lower ball joints, tires, and alignment this week. Already replaced the idler arm and I have put a lot of money into the engine. ( full tune up, fuel pump, new injector assembly) I am looking at about $1000 this week alone. Are there any definitive tests I can do to determine what the next step is to get my 4wd working properly?
If you disconnect the encoder motor from the tbox, can u switch the tbox manually with a wrench into all positions and have drive?
Old Feb 17, 2013 | 02:16 PM
  #22
Chris Jessee's Avatar
Chris Jessee is on a distinguished road
I haven't tried it with the new encoder. The last time I disconnected the tccm, it worked in all positions, for a few tries
Old Feb 17, 2013 | 08:10 PM
  #23
Due to the fact that it gave me lots of trouble changing the encoder motor, I don't really want to pull it back off and try shifting it manually. If it works correctly a few times after disconnecting the tccm, would it be safe to assume that replacing the tccm would fix it?
Old Feb 18, 2013 | 07:00 AM
  #24
Irish07's Avatar
There are contact points in the encoder motors, if the required contacts are not seen when the encoder motor shifts to 4HI..systems goes to default and backto the previous gear change.
It could also be a TCCM..something is either blocking the gear change or the TCCM is just not seeing the required gear change position in the requested position when the selector shaft is moved..either TCCM, or encoder motor, or wiring, or tbox..hehe thats really the whole system of parts to make the gear change..but if you can delete the thoughts of a possible mechanical fault, your half was there
But even with the old encoder off, did you try to move the tbox though the gears and see if there is drive in those positions?
Old Feb 18, 2013 | 08:06 AM
  #25
I didn't try it when I changed the encoder. I do know that it does work in all positions, I can get 4hi to work occasionally. That is one reason that I am leaning towards replacing the tccm. The new encoder solved one issue, just not all of them. I would like to find a wiring diagram with correct voltage readings, so that I can the entire system properly
Old Feb 18, 2013 | 11:02 AM
  #26
I am happy to say that I do believe my 4wd is fixed. I disconnected the tccm for about 30 to 45 minutes and did the ignition cycle 5 times. It now works in all positions. I cycled it through all 3 positions multiple times while driving up and down the driveway for about 5 minutes. Ran a dtc and there are no codes. Just need to find a field or gravel lot to give it a thorough test.
Thanks to everyone for all you help.
This is an awesome group.
I can only hope that my trails with my 4wd problems will help someone else.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
spmeyer76
Dec 23, 2010 08:21 AM
LinkTGF
May 23, 2010 10:05 PM
BluBlazin
Oct 12, 2009 11:38 PM
redpeppers
Apr 7, 2007 04:55 AM
