1998 Blazer Alternator help
ok i have a 98 blazer and i am running a jl 1000rms amp with 2 12 kicker cvr dual voice coil subs the system is drawing way to much power from my charging system to the point it wont keep up charge even when driving. i have an oversized alternator and batt already i am going to hook up another batt but i wont to install a second alternator i think where the ac pump is i dont use it can somebody tell me how or if there is another spot i can do this at
Back in the day, a car audio and alarm shop I worked at designed and installed many winning competition sound-off vehicles . Normally A couple stillwater designs kicker 12" subs and one JL Audio amplifier would not create the issues You seem to be having ... is that amp a class D or is it and AB ?
What guage wire are You using ? BASS is great , but mids and highs need to represent ... are You them on head unit power ? Is there a 4 channel amp You forgot to mention running ? More accurate system info will be required to provide any meaningful to You
![Icon Speaker1](https://blazerforum.com/forum/images/smilies/icon_speaker1.gif)
it is a class D mono block amp i am using 4 gauge wire and i run all 6 speakers off the head unit i have not installed a amp for them yet and when i turn up the sub lvl thats when i have the problem with the power in the whole truck as for bass some would say its overkill i do not tho my mids and highs are right there with the bass neither over shadow the other
74shark
10-14-2014 03:26 PM
