1998 blazer cranking problems
Old Jun 30, 2010 | 10:29 PM
wtjarrard's Avatar
wtjarrard is on a distinguished road
Default 1998 blazer cranking problems
Kinda new here, had the blazer for a few months, it's my 3rd S10 blazer but the only one i've ever had problems with.
1998 4x4 4dr S10 Blazer
symptoms:
- gets 14 mpg.
- it will eventually crank if i just turn the key but it has to turn over for several seconds
- if i pump the gas pedal though it cranks quicker but still not as quick as it should...
- the engine runs cold, about 120 degrees. replaced thermostat and no change
Old Jun 30, 2010 | 10:49 PM
wlorton's Avatar
Do you run all time 4x4? When I run 4x4 I get about 15 mpg.....
The cranking symptoms, no idea.... But I imagine if you are running cold there has got to be something wrong.....
Old Jul 1, 2010 | 09:11 AM
wtjarrard's Avatar
I run 4x4 most of the time in the winter because I live in Alaska, but it's not in 4x4 at the moment.
Old Jul 1, 2010 | 11:29 AM
84BlazerS10's Avatar
Have you tried checking your battery it might not have enough cold cranking amps for your location.
foanc
17
Apr 3, 2012 03:16 AM
Freise
Mar 16, 2012 11:27 PM
LilSki
Oct 12, 2010 09:56 AM
trishharris
Aug 4, 2010 10:38 AM
justin1795
Feb 9, 2009 05:07 PM
