1998 Blazer LT 2 issues
Just purchased for my son and 2 known issues are present. Rear Wiper does not work, no chatter, no sound no nothing. Secondly the rear view side mirrors do not adjust with the control on drivers door.
I replaced the fuse for both and no luck. Any troubleshooting tips? I'm assuming after reading this forum, I need to replace the rear wiper motor, but troubled with the mirrors.
Any help appreciated.
Thanks
Thanks
I would say at the very least you need to pop off the rear trim work and test for power to the motor. If you have power to the motor, but it still does not work, then I would replace the motor. If you do not have power, then your problem is forward of the motor; in either the wiring or the switch. You could then test the switch for proper operation.
On the mirrors, again, I would start at the mirrors themselves. Test for power at the mirror when the switch is activated. If you get no power on any of the wires, then I would move to the switch. You will need to remove the door panel to gain access to this wiring.
Daddydustin
06-09-2012 08:30 PM
evinrude
09-15-2010 10:37 AM
KIllarb634
12-20-2007 10:31 PM
