1998 Blazer not going into 4x4
Old Feb 10, 2011 | 07:10 AM
When you spin one front wheel, does the other spin in the opposite direction? If so, then the front axle is locked in and what you are observing is the differential in action. If you can spin one wheel with the other one remaining fixed, then the front axle is not engaged.
Old Feb 17, 2011 | 05:01 PM
Schm's Avatar
Schm is on a distinguished road
The front axle is not engaged.
Old Feb 17, 2011 | 06:57 PM
And the cable is being pulled 1/2" to 3/4" when the truck is put into 4HI or 4LO? If so, and you have verified that the cable is properly connected at the front axle, then you will have to drop the passenger side extension tube and get at the shift fork/collar inside.
Old Feb 18, 2011 | 11:21 AM
Schm's Avatar
Whats the best way to check to see the cable is getting pulled?
Old Oct 19, 2011 | 06:29 AM
Schm's Avatar
Default 4x4 help
Ok guys my transfer case shifts and locks into 4hi, 4low, and the front axle locks in so you can't spin it by hand like it should, but my front hubs won't lock in now I looked at the actuator or w.e its called under the battery box and it does not move when I engauge the 4x4 so its not pulling the cable it is getting vacume there so my question is what else actuate that to move and pull that cable?
Old Nov 25, 2011 | 10:31 AM
As I said, if you have already looked at the cable under the battery and it is moving 1/2" to 3/4", and you have verified that the cable is connected at the front axle (follow the cable to the front axle & unbolt the housing - 3 bolts) and make sure that it is connected to the shift fork.
I have combined these two threads. Please stick to one thread on a discussion. It is on you to bump the thread if you are not receiving responses.
There is A LOT of information in the Tech Article section. Please have a read through what is available and use some of the terms in those threads to search for other threads that might give further information. The 4wd systems on these trucks have been discussed in great detail in the past.
Old Nov 26, 2011 | 10:21 AM
Schm's Avatar
I looked at actuator under the battery box and it is engage (Sucked in) all the time? So if i have it in 2hi the actuator is still Pulled in, I have looked at the cable it is connected and i follow the cable to the front axle and took the 3 bolts out but i could not pull it out so I'm guessing the cable is connected to the fork
Chase Clouser
Jan 24, 2014 04:36 PM
kirkito
Dec 30, 2013 08:27 PM
randrm
Jan 25, 2011 02:51 PM
Boiler_81
Dec 2, 2008 10:04 AM
SnowRemorse
Jan 4, 2008 11:26 AM
