1998 blazer sputtering loping above 60 mph
Old Nov 25, 2010 | 07:57 PM
mritech's Avatar
mritech is on a distinguished road
Default 1998 blazer sputtering loping above 60 mph
my 1998 blazer 4x4 sputters lopes at > 60 mph. no trouble starting, idling. has 190 k on odometer and had complete tuneup at 130k which included catalytic conveter replacement along with o2 sensors. can cat clogg so soon after replacement ? have burnt 87 octane since buying her and wonder can that choke out a cat? ses light on and im going to write down codes after trip to advance auto. also new fuel pump and filter replaced less than a year ago. love my blazer and i want to drive her for many years to come. one last thing, overhead compass/ temp display quit working one day and i cant sem to find where to find fuse/relay wiring to test voltage. any help would be appreciated during these trying econpmic times. thank you
Old Nov 25, 2010 | 08:42 PM
1998MSO's Avatar
1998MSO is on a distinguished road
The octane rating has no effect on clogging a catalytic converter. However, if you engine has been running too rich or inefficiently, that can clog 'em up. Get those codes and come back here with 'em, that's the first place to start.
Old Nov 29, 2010 | 11:55 AM
mritech's Avatar
Default got the obd code for sputtering loping 1998 blazer
went to advance auto and scanner puts out P0325. i think my book says its knock sensor circuit as error code. now i think vehicle has 2 sensors one for each side of engine block. where are they exactly, and how do i test each of them to see which is bad? are they hard to replace ? any help would be appreciated thanks. lopes and sputters above 60 mph.
Old Nov 29, 2010 | 08:05 PM
There is only one knock sensor and it is located behind the driver side cylinder head on the back of the block slightly more towards the center of the engine.
P0325 - Knock Sensor 1 Circuit
Outsydr
May 10, 2010 10:40 PM
peters702
Jan 29, 2010 10:50 AM
dustinsroberts
Oct 15, 2009 12:08 AM
dwaple303
Jan 27, 2009 03:30 PM
ruxpin76
Oct 28, 2008 10:04 PM
