1998 chevy blazer 4dr. Fuel pump issue!!!???
Old 09-18-2023 | 03:57 PM
Jrt71282's Avatar
Jrt71282 is on a distinguished road
Default 1998 chevy blazer fuel pump relay
OK, there also labeled black, white, red and purple I believe, I will look for the 24 pin connector with wire you referring to,after I find that wire, what would be the next step?
  #42
Old 09-18-2023 | 04:08 PM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
Post #38.
  #43
Old 09-19-2023 | 09:13 AM
Jrt71282's Avatar
Hello George, I proved that pin, with dark green and white stripe, I believe is pin 1, on the 24 pin connection going into the ecm, I back proped the backside of the wire with negative lead on negative battery terminal, with key on, and the multimeter set to ohms, I got 0.35 ohms as a reading, now its set on the lowest 20k ohm reading, I also tried setting it in DC volts at lowest setting, and wasn't able to get a reading or any volts, but it does get the ohms reading?
  #44
Old 09-19-2023 | 09:43 AM
GeorgeLG's Avatar
You want the meter set to DC volts and your looking for the behavior in the first few seconds at key on. You can’t set the meter to the lowest dc volt range or you will get an out of range display. Use auto range, the 20v range or the first one above that.
Did you say that you replaced the engine computer? If so, why? Are all the connectors properly seated with no bent or broken pins?
George
  #45
Old 09-19-2023 | 10:23 AM
Jrt71282's Avatar
Yes I replaced the ecm because the original one was burnt and no good, I bought the blazer used, the person who sold it to me didn't tell me about the computer being faulty, also I hired a mobile mechanic last month to come out and fix the blazer, that it was a crank no start, he hooked up a scanner and said that the computer was no good, so I replaced it, bit the main reason it wasn't starting was it was out of time, I believe the pump went out from me trying to Starr the vehicle over and over before realizing the timing was off, now that it's in time and will start up, it's the issue with the pump no coming on, the connections going to the computer are in all the easy, no broken pins, but when I took the connections off to replace with the new computer, some were brittle, the plastic clips broke, but I managed to pushed the connections all the way in. I may have to replace them with newer ones, if this is then issue?
  #46
Old 09-19-2023 | 10:27 AM
GeorgeLG's Avatar
What is the result of the voltage test with the meter on the correct scale?
George
  #47
Old 09-19-2023 | 10:42 AM
Jrt71282's Avatar
It's not showing any voltage with the key turn on ???
  #48
Old 09-19-2023 | 10:43 AM
Jrt71282's Avatar
And I did have it on pin#1
  #49
Old 09-19-2023 | 10:44 AM
Jrt71282's Avatar
On the ecm it reads black and white, the black one has the 24 pin, and the white has the 32 pin
  #50
Old 09-19-2023 | 11:03 AM
LesMyer's Avatar
LesMyer will become famous soon enough
This one is pretty interesting! George will get you fixed up!
Quick Reply: 1998 chevy blazer 4dr. Fuel pump issue!!!???
