1998 chevy blazer
Old Dec 16, 2006 | 06:45 PM
abamsrg's Avatar
abamsrg is an unknown quantity at this point
Default 1998 chevy blazer
I have a 1998 Chevy Blazer and it will start then it will die. I have replaced the ignition switch, and the computer,
Old Dec 16, 2006 | 06:50 PM
hillbillyinOhio's Avatar
Default RE: 1998 chevy blazer
fuel pressure good?
Old Dec 16, 2006 | 08:22 PM
abamsrg's Avatar
about how much pressure does it take i know on my old 1994 blazer it took 45-55 pound of pressure
Old Dec 16, 2006 | 08:48 PM
i think around 60.
Old Dec 16, 2006 | 08:50 PM
abamsrg's Avatar
i am getting ready to test it
Old Dec 16, 2006 | 10:26 PM
cayveman's Avatar
cayveman is an unknown quantity at this point
I have a 2003 Blazer we fought a similar problem on. It always started fine. It would run occasionally without any problem, but generally would die after starting or it would idle rough one time and then fine the next. It turned out to be a bad ground strap. It was fastened well, but wasn't allowing a good ground. Ours was still under warranty when repaired andwe haven't had this problem since.
Old Dec 17, 2006 | 02:11 PM
blazinloud's Avatar
I had the same problem, twice.......once I had to replace the fuel pump/filter. the next time a bottle of gas line antifreeze did the job, or seem'd to anyway......
Old Dec 18, 2006 | 02:51 PM
abamsrg's Avatar
Thae fuel pressure is 60to 66 lbs
Old Dec 19, 2006 | 10:46 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
How much gas is in the tank? Over 1/4 or not
When did you change out the fuel filter last?
What else does it show/do when it starts to or does die?
Old Dec 19, 2006 | 04:28 PM
abamsrg's Avatar
it has a 1/2 of gas and i change out the fuel fliter about two month ago and ran fine for about three weeks.
aaronjohn20
Jul 8, 2009 05:53 PM
Mitchmath
Apr 28, 2009 05:56 PM
jaydog_10
Jul 27, 2007 12:39 PM
walkingtall
Oct 8, 2006 07:19 AM
thanser
Dec 7, 2005 05:18 PM
