1998 chevy blazer oil leak problems
Old Nov 27, 2013 | 04:06 PM
bradw1984's Avatar
bradw1984 is on a distinguished road
Default 1998 chevy blazer oil leak problems
I have a 1998 chevy blazer that I bought recently and noticed it has an oil leak, but I dont know where its coming from. I took it to a shop and they said they couldnt see where its leaking, and all they could do is run a few tests for like 150 dollars. So I was wondering if anyone could help me out...... thx
Old Nov 27, 2013 | 04:09 PM
jpimp's Avatar
jpimp is on a distinguished road
take it to the car wash, spray and re check
Old Nov 27, 2013 | 04:32 PM
bradw1984's Avatar
ok thanks i will have to try that, i thought it was the oil pan gasket, but i couldn't find any oil leaks there, so i was wondering if it was the main seal leaking...
Old Nov 27, 2013 | 11:00 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
Sounds to me they just want your money!!!! $150? Jesus I can only imagine what they'll want once they find it....
Old Nov 27, 2013 | 11:03 PM
07nhbpsi's Avatar
Soo u noticed it's leaking just not sure where? Is it 4wd? If so, a very common problem is the oil cooler lines.......surely u know of the general area right??
Old Nov 28, 2013 | 08:37 PM
bassson's Avatar
bassson is on a distinguished road
maybe the previous owner did a sloppy job on the lower intake manifold gaskets.
that's where mine was leaking from. My mechanic couldnt find the leak either with just a quick inspection. you going to have to crawl under the blazer with a flashlight and see how high up you can see the oil.
It would be leaking from the back of the gasket by the distributor
Old Dec 3, 2013 | 03:13 PM
bradw1984's Avatar
Yeah I have been under it and found out where its leaking and it looking like the oil lines are bad, the condom looking thing on the line is pretty bad. Im gonna have to replace them, is it hard and is it exspensive?
Old Dec 3, 2013 | 03:42 PM
flypaper's Avatar
flypaper is on a distinguished road
its not that hard,just messy.
make sure you get the ac delco lines, not the aftermarket junk
they cost around 80 bucks
you will need a 20 inch long extension to get a socket onto the bolt
on the engine side
i read that some guys eliminate the whole oil cooler system all together
and where the lines go into the block will put a adapter
for a oil filter there.
i will do that myself if next time happens again.
Old Dec 3, 2013 | 08:17 PM
07nhbpsi's Avatar
It's not that bad.....get u a block of wood and a jack to raise the motor up so u can pull the lines out, otherwise they will get hung up on the motor mount!!!!! btw., do a search I personally would just go have u a couple of high pressure lines made up and cut the aluminum lines where they are crimped .....then just put the replacement lines on and clamp them down!!! I ended up using the aftermarket onewell I already replaced them once, next time I'm gonna cut the rubber lines off and have some high pressure hydraulic lines made to replace them.........
Old Dec 3, 2013 | 09:40 PM
^^ Yup, been there, did that, no more leaks. Aftermarket and OEM lines are not the answer, they will leak again, guaranteed. Cut the old aluminum crimps off, (not the aluminum tube) and use compression fittings and hydraulic line. Good to 3000psi... plenty good for 80psi of oil pressure Cost about $60.
ThatGirl1971
Oct 8, 2013 11:24 AM
ComputerNerdBD
Mar 20, 2013 12:33 AM
Webb_d
Jul 23, 2012 08:21 AM
BubbaBrooks
May 18, 2011 08:38 PM
TAZ454
Jan 28, 2008 10:11 AM
