1998 S10 Blazer just stops running!
Old Aug 31, 2012 | 11:23 AM
Don Bennett's Avatar
Don Bennett is on a distinguished road
Default 1998 S10 Blazer just stops running!
I have a 98 Blazer that will just **** the bed for no apparent reason. Truck will start, maybe go 5 miles or maybe even 25 miles and buck a few times and just shut down. It will still crank but will not start. After an hour or so, truck will start and the process repeats! Has anyone ever had any problems like this? Any ideas or direction would be awesome.
Old Aug 31, 2012 | 12:03 PM
50lb_cat's Avatar
I would start with a fuel pressure and leakdown test. Do the test witht the key on, engine off. Your initial number should be between 60 and 65 and not go below 55 for 10 minutes. Post back your numbers.
Old Aug 31, 2012 | 12:50 PM
Im not a mechanic....I dont have a fuel pressure tester thing....Im almost certain I have an electrical issue.....Thanks for your help though...Its a 98 blazer...the tester probably costs more than the pos is worth....lol
Old Aug 31, 2012 | 03:52 PM
richphotos's Avatar
You can rent fuel pressure gauges from auto parts stores. get your money back upon returning the part.
Old Aug 31, 2012 | 04:30 PM
50lb_cat's Avatar
+1, if you have ever checked the air in your tires, its that easy. And why ask for help if you don't like suggestions?
bigbird82
Nov 22, 2011 04:32 PM
JMAC
17
Apr 7, 2009 11:32 AM
cardsNblazer
Aug 11, 2008 08:26 AM
JMAC
Mar 22, 2008 12:04 PM
thevair65
Apr 11, 2007 02:25 AM
