1999 blazer 2wd engine in a 4wd???
Old Mar 29, 2013 | 12:08 PM
rexmburns's Avatar
Super Moderator
What do you mean you traded the intake manifold? Did this motor have the older aluminum intak on it? I don't have my truck in front of me to compare to but this looks like one of the pre96 motors to me. I coil be completely wrong hopefully someone will chime in soon. Off hand I know my oil filler neck is on the back passenger side of the motor not sure I that matters or not.
Old Mar 29, 2013 | 12:15 PM
nathanb198's Avatar
nathanb198 is on a distinguished road
both engines had the black plastic manifold. the oil filler is on the drivers side of both engines.
Attached Thumbnails 1999 blazer 2wd engine in a 4wd???-img_1327_zps72abbe94.jpg
Old Mar 29, 2013 | 12:22 PM
rexmburns's Avatar
Super Moderator
Hmmmm.... well I really wish I had a motor to compare to in front of me!! Could it be the motor mounts? I think but am not certain that the mounts were taller in a 2wd. Either that or I think I remember reading that somewhere lol!
Old Mar 29, 2013 | 12:34 PM
nathanb198's Avatar
chevy dealer says that theres no difference is motors between 2wd and 4, other than the oil pan, and remote oil filter assembly. but i dont know if i have the same year or similar year of engine
Old Mar 29, 2013 | 12:40 PM
nathanb198's Avatar
anyone know what this is... just broke it its right next to the dizzy hole, my guess is an oil pressure sensor.
Attached Thumbnails 1999 blazer 2wd engine in a 4wd???-img_1328_zpsc4ffeff1.jpg
Old Mar 29, 2013 | 12:41 PM
rexmburns's Avatar
Super Moderator
I just reread my last post and meant to say that the 2wd mounts are shorter as they don't need the space for the front diff. That is the only thing I can think that would be causing the motor to sit lower and in the way.
Well hopefully someone smart (unlike me today) will come along and help out!
Old Mar 29, 2013 | 12:59 PM
rexmburns's Avatar
Super Moderator
Whats the engine serial number?
Old Mar 29, 2013 | 01:38 PM
coolasice's Avatar
coolasice will become famous soon enough
did you lower your transmission to get to the bell housing bolts? is the transmission connected to the motor when you tried the test fit?
Old Mar 29, 2013 | 01:55 PM
nathanb198's Avatar
i figgerd it out.. lol nevermind oil pressure sensor. the engines number is 2517655 the blazer is a 4wd, the replacement engine is from a 2wd
i have had it in and test fit and it was too deep for the mm and the front diff, but i think that may have been due to the oil pan being for a 2wd, i have the pan replaced with the 4wd pan and havent put it back in yet, just trying to cover the bases before i put it in and have to pull it back out AGAIN
Old Mar 29, 2013 | 01:59 PM
rexmburns's Avatar
Super Moderator
Well what was it???
