1999 Blazer Help Needed
Old Oct 25, 2013 | 10:23 PM
G3N7RY's Avatar
G3N7RY is on a distinguished road
Default 1999 Blazer Help Needed
I have multiple issues right now with my 99 s-10 Blazer LT 4X4.
The most annoying one is my heater. The issue is when I turn it on, no matter the fan speed or setting, it will blow out from all the vents, floor and dash and also windshield blower. It also does not allow me to change the temp. What it does is blow hot for a few seconds then blows cold for a few seconds and when it goes back to hot i have an annoying squeak sound in my dash. Any Idea what I can check or look into to try and fix this???? Winter is right around the corner and I need my heat.
Second, it will not let me switch it into 4WD. If i hit the button like I have a million times before, it just blinks for about 30 seconds then go back into 2WD. I have no idea what to do about this.
Third. I have a very loud whinny noise coming from my rear end when I let off the gas. I'm thinking barrings but not 100% on this.
any help would be great. thanks
Old Oct 26, 2013 | 04:32 PM
spittybays
Guest
Posts: n/a
https://blazerforum.com/forum/tech-a...ill-help-7180/
https://blazerforum.com/forum/tech-a...acement-29981/
These are both from the DIY section on the homepage. There is a lot of good stuff there along with an alternate blend door replacement.
Your whinny noise could be a whole bunch of stuff but most importantly you need to check for oil in the rear differential and your U -joints
Old Oct 26, 2013 | 06:38 PM
Does the vehicle have manual HVAC:
Or does it have Automatic Climate Control:
Attached Thumbnails 1999 Blazer Help Needed-98-01climatecontrol_zps67799254.jpg
Old Oct 26, 2013 | 09:40 PM
TMM217's Avatar
TMM217 is on a distinguished road
On the rear squeak it may be as simple as the dust shields rusting and rubbing on the rotors.
Old Oct 27, 2013 | 12:01 AM
G3N7RY's Avatar
I have the top one the HVAC
And thanks for the responses, I will start looking at those threads right now
Attached Thumbnails 1999 Blazer Help Needed-manualhvaccontrol_zpsa9241ad9.jpg
Old Oct 28, 2013 | 02:06 AM
G3N7RY's Avatar
Default Thanks
hey man thanks a lot for the link, I was able to locate a broken hose on my vacuum line, fixed both my heater and 4WD
kamilkowalski
Apr 30, 2015 08:36 PM
Dobe Rottie Gang
Aug 29, 2013 05:14 AM
Nandy
Apr 1, 2013 05:26 PM
inherited94s10
Jul 18, 2007 12:19 PM
blazin4eva
Feb 26, 2005 12:04 PM
