1999 Blazer won't start after it rains. Runs great after it drys out?
Old Aug 2, 2019 | 08:54 PM
burnsdomain's Avatar
burnsdomain is on a distinguished road
Default 1999 Blazer won't start after it rains. Runs great after it drys out?
Hello all: I have a 1999 Blazer 4 door 4X4 and when it rains I can't get it to start. I have replaced the distributor, wires, spark plugs ( it needed it anyway), crank sensor. cam sensor, check the fuel pump and pressure. I check the electrical aspect and all was good. I even tried a different ignition control module but still no start. Is there anything else I need to check? The truck sits outdoors due to I live in an apartment. What else would cause the truck to not start after it rains? The truck does crank over fine and the starter was replaced a few months back. Any ideas or helpful advice would be greatly appreciated.
Thank for your time and help.
Old Aug 3, 2019 | 09:56 AM
rriddle3's Avatar
* Moved to '2nd Gen Tech' *
Old Aug 3, 2019 | 11:00 AM
GeorgeLG's Avatar
What do you mean that you checked the electrical aspect and all is good?
When it won't start, check and see if you have 1" of strong blue spark at the end of a spark plug wire (spark plug end).
George
Old Aug 10, 2019 | 12:59 AM
Rock18's Avatar
Rock18 is on a distinguished road
Wet air filter? 🤔
Is it showing any codes?
Old Aug 11, 2019 | 07:25 AM
In my experience, wet weather often exaggerates ignition system (spark) issues. This is diagnosed most easily by using a spray bottle of water to mist over the engine while it is running at night or in a dark place. The water mist will show you if you have any spark leak from the various ignition system components (wires, cap, coil/icm). Even though you have replaced most all of these components, I would still recommend this diagnostic step to rule out an issue with those new parts.
The next thing I would check is the drains in the bottom of the distributor itself. You can do this by removing the cap, rotor, and cam position sensor, then blowing compressed air through the drain hole. If I remember correctly, the factory distributor has a screen in the drain that can get gunked up and actually hold moisture/humidity.
Muddigger86
Sep 28, 2015 10:47 AM
jcwilliams
Aug 15, 2015 06:44 PM
er0ck273
Jul 29, 2014 07:20 AM
jm01gt
Mar 25, 2011 06:57 PM
rkosu02
13
Feb 27, 2011 06:53 PM
